77 impala heater controls
hectorvenezula
So I have an impala that doesn't have ac and no matter where I look I can't find the controls without ac. I have a small broken part that makes it so I can't change the temp to cold for the vents
dloftis1
2
Most likely cable driven and the piece broken is plastic on the heat, temp control to the cable. You might have better luck getting a control head from an parts (junkyard/used) AC car and hook it up to your car knowing that the AC part of the control will not work for you. Just a thought.
